John Deere No. 38 Mower Info Needed
Scott Tn.
12-29-2001 20:50:52
I have recently just got a No. 38 John Deere Mower. I want to know what years they were produced and if anyone can give me some advice on it. I am going to try to run it on a 1949 John Deere A. It has the cable lift and is in pretty good shape. If anyone has a manual for one I would be interested in buying it or maybe someone sending me copies of it. Thanks for all the help.
Scott Tn.
Larry D.
01-01-2002 17:18:02
 Re: John Deere No. 38 Mower Info Needed in reply to Scott Tn., 12-29-2001 20:50:52
Scott the 38 is a very nice mower. It was available with 3 choices of lift. A cable like the one you have a hydraulic cylinder and believe it or not a rope pull lever.You can get the manuals by calling Deere publications at 1 800 522 7448.
The manual contains information for the 37 38 and 39 it is number OPM H62916. Also I have a copy of predelivery instructions PDI H62915 that is very helpful.I sure like my 38 and use it with a 520. Good luck.
Larry D.
JK-NY
01-01-2002 06:57:34
I had a 38 JD mower. It was a semimounted mower which hooked on 2 round brackets which bolted to the outside of the drawbar frame of a JD 2 cyl. tractor. (similar to mounts for #5).It was hyd cyl lift . Other post is correct go to your JD dealer, they can get you a new manual for most anyting they ever built..Ask them for a catalog of the old manuals. I have one here and would of looked up the # for the one you need but couldnt find it just now.
Joe
01-01-2002 03:27:19
Scott, I am pretty sure the #38 was a 3-point cylinder lift mower. Identical to the #37 (which I use) only the #37 is drawbar mounted. I am not sure what the model is that is cable lift.
larry h
12-31-2001 16:29:01
i thought a 38 was a cylinder lift
Clem
12-29-2001 21:28:08
Manuals are available from John Deere. Most all parts are available from JD and farm stores can provide some parts, also. A parts catalog and operator's manual are highly recommended.
