Plans for NH rake hitch
dab
12-28-2001 09:45:39
Anybody out there have plans on how to make a hitch to pull 2-NH 256's at the same time?
David
12-28-2001 16:17:16
 Re: Plans for NH rake hitch in reply to dab, 12-28-2001 09:45:39
I built a hitch for my n.h. rakes a few years ago out of 4 inch square tubing and a rear axle from a John Deere combine The hitch hooks to tractor with the first rake hooked right behind it, then is like a goose neck over the first rake then down to axle of combine were the second rake is hooked to a hitch welded on the axle,uses the original sterring cyd to move the second rake to the right or left.Can put two windrows to one side or make two separate rows
snowball
12-29-2001 20:35:08
 Re: Re: Plans for NH rake hitch in reply to David, 12-28-2001 16:17:16
My neighbors pull 2 NH rakes. All they did was welded a heavy piece of square tubing across the back and another piece that just fit inside and then drilled it and welded a not on it.Slide in for transport and out to race with. I have racked with it and it seems to work good. They blae anywhere from 500 to 100 big round bales,plus 500 0r mre square a year.
