Jd corn planter?
jared
12-19-2001 19:09:39
please help me I pickedup an old john deere planter 2 row but I don't know what it is. it has no model # on it. it has 2 v blades in the front then the shoes where the seed drops then 2 discs then the 4 smaller wheel packer.the hitch is also different it has a spring and a bar with a spring loaded pin.need some parts but don't know where to start. an old timer said maybe a lister? thanks
Jerry S
12-27-2001 15:41:22
 Re: jd corn planter? in reply to jared, 12-19-2001 19:09:39
I can't necessarily tell you what you have based on your description but I can tell you a couple of things I read. John Deere made planters with Mansur from the late 1800 into about 1911 and these would have a planter lid that said deere and mansur co. on them. The first ones were with a kind of square seed box that appears to be wood. Deere made the two row planters well into the 1940's or 50's it appears. The difference is easy to tell if it is a lister because a lister looks like a plow that throws dirt both directions not just to one side. You should post back with more detail about your planter like what the lids say on them, does it have the plow like fixture or not, is there/was there a wooden tongue, was it a 3 point setup or just an iron pull tongue setup etc. There was something called a checkwire that was used on some old models and you can tell it by looking for some spools on the sides of the planter. they don't usually look like they belong there for anything because most checkwires are long gone it seems. Good luck and hope this helps you.
