Tandem 3pt Disc
SamMI
12-15-2001 06:26:50
I have located (2) dearborn 7 ft disc's. One is a Type "E" and seems in fair shape. The other is same or similar but no name plate. Owner say's it is a Ford disc. He has weight boxes welded to the frame and the disc. and shows several rewelds on frame members. My question is; Is it necessary to add weights to these 3pt disc's to get penetration. Would like to hear from folks using these disc's. I would pull with Ford 601. Thanks
PCC-AL
12-16-2001 02:43:31
 Re: Tandem 3pt Disc in reply to SamMI, 12-15-2001 06:26:50
Hi SamMI,
I think your answer will depend on the composition and condition of your soil.
I have never used weights on my disc. However, I usually plow the ground first and disc after the soil is turned. I do have one fairly sandy field that I can disc without plowing, but I like to get the grass and weeds turned under good. Good luck.
