Thrower for 24T Baler
Karl in MD
12-13-2001 10:49:29
Can anyone tell me what model bale thrower(s) will fit a John Deere 24T baler. I'm looking at one which has a thrower drive on it, but no thrower. Also, can anyone give me any advice about using a thrower. I've never worked with one before. TIA, Karl.
John
12-13-2001 13:53:28
 Re: Thrower for 24T Baler in reply to Karl in MD, 12-13-2001 10:49:29
karl I have a 24t with a thrower I think a model 30 but Im not sure it fits the 336 too. as far as using it you can turn it off and let the bales fall on the ground or turn it on and throw the bales on a wagon they have a control for how hard it throws them so you can change as you bale also a hyd turn so you and adjust for turns and wind. they are made to throw into a wagon with racks or turn way down and the bales land just on front of the wagon and then stack them.
Tim(nj)
12-13-2001 19:31:24
 Re: Re: Thrower for 24T Baler in reply to John , 12-13-2001 13:53:28
The 24T originally used the #2 mechanical drive ejector. This model could only throw small bales. The mechanical drive was a pain, and many parts are no longer available for the #2. The #30 ejector uses hydraulics, allowing it to throw a bigger bale. A pump is mounted under the baler and is driven by belt off of the flywheel. I have two 336 balers with #30 ejectors, and they work OK, as long as you keep your bale length consistent. Go too fast and push the bales through the chamber before the pan can relatch, and you'll curse that thrower.
