Info on Farmall H Implements for Farming
Scott L. Swanso
12-12-2001 09:54:28
I need to buy some implements for my Farmall H to be able to plow and plant corn and alfalfa/grains. What do I need to get started? Be specific. If anybody out there has implements for sale, let me know. I am in Roseville, MN.
I need a plow,disc, corn palnter, drill and what else? I appreciate the information greatly. I am new to this but have lots of drive. The corn/grains will be for food plots for deer and squirrels.
Thanks again
Country Bill
12-13-2001 19:01:39
 Re: Info on Farmall H Implements for Farming in reply to Scott L. Swanson, 12-12-2001 09:54:28
I have found both a "drag type" brush hog and disk that work great behind my H that does not have a three point,in other words I use them with a '"draw bar"
snowball
12-15-2001 19:08:57
 Re: Re: Info on Farmall H Implements for Farming in reply to Country Bill, 12-13-2001 19:01:39
The pull type discs work well but they are hard to move anywhere. Bought one a few years ago and then started wondering how I was going to get it the 3 miles to home. Got lucky and found out something I didn't know they actually made wheels that you put under the end of each gang and then just pull it. can't get in big hurry as wheels are metal.
1PWRFULH
12-12-2001 20:01:09
Scott, The stuff you need can be easily purchased at auctions and look in your local trader. Any kind of 2 bottom trailer plow will work- hydraulic or manual or if you have a 3 pt a 3pt plow can work. Disc- just go with a pull behind 8 or 9 foot. This stuff usually sells for pretty reasonable. Good Luck.I did some planting for game this year and it turned out great. you'd be surprised what that Farmall will do!
RC
TomH
12-12-2001 17:43:47
Contact your state game commission. I don't know about Minnesota, but here in PA they will give you bags of seed corn for game food plots. I've heard deer love buckwheat too.
paul
12-12-2001 14:52:02
You could use a spinner spreader for seeding small grains instead of the drill. Up to you. (Do you have a 3-point on your H? Will make a big difference on what implements are available for you.)
I would want a harrow (aka drag) to flatten ground, cover small grains, and uproot weeds a week after planting corn.
I would also want some type of mower or bush hog to cut down hay & grass.
You will need to keep the weeds down in the corn, either a sprayer or a row crop cultivator - the cultivator needs to match the rows & row width of your planter.
You may want a small field cultivator for working up the ground. This would do about the same thing as the disk, you would only need one or the other. Since most small old field cultivators have problems letting trash (last year's straw/crop) flow through I guess the disk is a better idea. The cultivator would loosen & rip up & dry out soils like we have here in the wet cool spring. A disk will pack down & harden the ground - but it also chops up trash & lumps. The big farmers have all parked their disks as modern field cultivators do a much better job, but the little guys all prefer disks. Just mentioning an option.
For food plots it maybe doesn't matter, but you might want some type of fertilizer spreader. A drop or spinner type. Depends how many acres you are talking about. You can hire this out too if it's several acres. The same with the spraying mentioned above.
--->Paul
