Johnson Workhorse Loader
LJordan
12-11-2001 20:07:18
I am trying to find out what the output pressure is for the hydraulic pump that operates the front-end loader. This is on a Ford 145 garden tractor. My reason is because about 15 years ago, my brother adapted a power steering unit from a Ford Comet to my tractor. Recently I had to replace the unit with a re-built one due to an oil leak. As soon as I applied pressure to the replacement unit, a major oil leak started. Should the power steering valve withstand the output from this loader hydraulic pump? The old one worked fine for 15 years. What could be the difference with the replacement unit? Thanks for any insight on this problem.
