Plow Share Question?
George
12-05-2001 06:17:09
On J.D.plow shares eg. 14" throw away style, plow shares were either available in short called high speed or long called regular(I think). The differance being the length of the share about 1-1/2,-2" longer on regular shares, My question is why the difference? I have used both, and have not noticed any difference in performance/life, or ease of pulling
ET
12-05-2001 12:41:49
 Re: Plow Share Question? in reply to George, 12-05-2001 06:17:09
The short share is called a narrow cut and the long one is called a full cut. The idea is that the narrow one leaves a strip of sod uncut to act as a hinge so the strip of soil will turn over better. If you look at what model bottom you have it would say for instance HS314NC. This means high speed 14" narrow cut.
Ducknose Bob
12-05-2001 12:20:32
The only thing I can think of is that on a 2 or 3 bottom plow at 3 or 4 MPH, you might not notice any difference, but when companies came out with tractors that could pull 4 or 5 bottoms at 5-6 MPH, there might be a difference in the amount of HP required between the different lengths.
