Making hay
Stan in AL
12-04-2001 12:27:58
Can anyone direct me to web-sites that have info on hay-farming? I've got an itch that needs scratching. Thanks.
Roy B
12-05-2001 07:04:51
 Re: Making hay in reply to Stan in AL, 12-04-2001 12:27:58
Stan In the summer of 2000 I tried to come up with a cost per bale for making a timmothy/clover mix for horses. I took the 5% of the value of my hay making equipement and tractors, added fuel, fertilizer,twine. Came up with 89 cents a bale. This amount does not reflect spring planting costs, time, maintence, or repairs. It also assumes all your equipement will last 20 years and will be replaced at 2000 prices. Not a real exact figure but it is a starting point. Hay was in short supply in this area this year and I still had trouble getting $1.50 out of the field. Hope this helps, I am sure the machine shop background will. Roy
Roy B
12-05-2001 07:04:38
PCC-AL
12-04-2001 17:01:25
Hi Stan,
You must be somewhere up north, like maybe Montgomery. Anyway, check out our Ala. Co-op. Extention Service. It's great, even if one of the main sponsors is Auburn (yuck). Good Luck.
Stan in AL
12-04-2001 18:47:59
 Re: Re: Making hay in reply to PCC-AL, 12-04-2001 17:01:25
Hey PCC,
I'm farther north than that. I might even qualify as a yankee! I'm just south of Huntsville. Thanks for the info.
George. MS.
12-04-2001 13:10:05
rollin' in it is a lot better
paul
12-04-2001 12:52:38
A lot has been written about it here, usually every early spring. Have you checked the archives & search engine on this site?
--->Paul
Stan in AL
12-04-2001 18:50:15
 Re: Re: Making hay in reply to paul, 12-04-2001 12:52:38
I've checked the archives for info on some particular balers and rakes, but not specifically for general info on making hay. Why didn't I think of that? Thanks.
F14
12-04-2001 12:33:03
Use a search engine to do a search on "Haying FAQ" and you'll get a bunch of hits. Here's one:
Stan in AL
12-04-2001 18:52:51
 Re: Re: Making hay in reply to F14, 12-04-2001 12:33:03
Thanks F14,
The link you gave was good. I'm just looking at raising bermuda hay for the local horse-owners. Seems that I don't know any better than to find some hard work to do. For some reason that looks better to me than working more hours in the machine shop. Thanks again.
DaveH
12-26-2001 12:35:06
 Re: Re: Re: Making hay in reply to Stan in AL, 12-04-2001 18:52:51
Hey Stan,
You gonna sprig or go with a seeded type? I'm about as far north as you ('cept I'm in ga) I've had fair results with Cheyenne (seeded type from Pennington) and I have neighbors working with Russel and tift 44 (sprigged)
