Seed Plates- which one?
Mark
03-09-1999 06:10:42
I have an old Cole duplex 1 row planter, this machine has two bins and two seed plates. You can plant two different crops at the same time or use one at a time. I guess you can get plates for corn for each side and fll both hoppers. this is what i want to do. The right one spins counterclockwise and left clockwise. I want to plant about 4 acres of corn, a sales company in atlanta has several plates. Which size (large medium or small seed) and row spacing should I get. Does the plates alternate so that one drops a seed and then the other? I also want to plant some peanuts and lima beans of about 4 200 foot rows. I do have these but wonder whitch variety does the best in labor after planting. Any help or advice would be appreciated.
thanks
stan
03-09-1999 10:24:58
 Re: Seed Plates- which one? in reply to Mark, 03-09-1999 06:10:42
alot of seed corn bags have the necessary plate type printed on the label somewhere
S. C.
03-09-1999 07:50:01
The Grade size of the seed corn determines the size of plate used. Med flat would use a different size of plate than a large flat.
