NH 269 square baler
JB
11-29-2001 12:34:32
How can i check if this baler is "in time"?
paul
11-29-2001 20:53:31
 Re: NH 269 square baler in reply to JB, 11-29-2001 12:34:32
I think the hay feeder chain also need to be set in time at the right time. If you want to check _everything_.
I would strongly consider getting a manual from NH or a vender such as the 'manuals' section in the upper left. Pictures can be worth a 1000 words. :)
--->Paul
Burrhead
11-29-2001 14:37:02
Check the baler frame next to the chain knotter drive and you'll find a chisel mark. Line up the chisel mark on the frame with the chisel marks on both halves of the knotter drive.
There's a chisel mark on the main frame beside the plunger drive rod, under the front long cover, and a chisel mark on the plunger rod. They should be lined up the knotter and tine timing.
With all the chisel marks lined up the feeder tine pivot connector should be at about 7 oclock on the drive wheel for the tine chain timing.
