What brand is it? Failing that, what color was it? Be easier to help if folks know that. Does the right-hand wheel line up in the furrow right? If it is in or out any different than the inner side of the original wheel, it won't plow right. Make sure this is ok, or forget the new wheels, won't work. You should be able to adjust the plow a bit deeper to make up for the bigger wheels, but how much did the tires raise it? You will need to level it off with the back end now as well, or the plow will be angled 'uphill' and won't pull into the ground right. Plows need to be angled & set right in all 3 directions. By changing the height of the front end, you may have upset the balance it had. You will need to find that balance again. A big reason for a plow not penetrating is the plow shares being worn down. Might want to try new ones, this is one of those 'always' the cause of problems things. (As to the harrow in your other message, around 'here' a complete one often sells for $25 or less, be sure you don't spend more on making a frame than what they are worth in your area.) --->Paul
