Need Help on Massey Ferguson Baler?
Mike Huber
09-13-1998 17:31:54
on my MF #9 Baler I have a proplem every thing runs like a clock The baler has been sittng for the last two years I oiled & greased every thing all up cleaned every thing up,Runs great but on the packer it rides on rails I oiled them up also But the rails are getting so hot that water will sizzle on it! I'm running at 65-70 strokes a minute there seems to be no hard friction will run at a idle no proplem What I'm I missing ? Thanks Mike Huber
Nellie
09-19-1998 16:26:29
 Re: Need Help on Massey Ferguson Baler? in reply to Mike Huber, 09-13-1998 17:31:54
Mike, I wrote you about my MF 10 awhile ago. I had the same problem when I bought the 10. Mine sat inside for a few years and was 'froze' up. My wife and I spent the 4th of July trying to get free. We got it loose finally and it ran good. If I disingaged the PTO it would almost stop on a dime. I kept putting oil and grease on those slides and after a couple of hundred bales it really freed up. My advise to you is just keep with the oil and grease. Don't get wild and start taking those slides apart.
I had to store my baler outside and every spring I had to grease and oil those slides good and wait about 50 or so bales until everything started running smooth. Keep working on it and watch for improvements after disingaging the PTO.
Mark / Wi
01-12-2004 11:21:43
 Re: Re: Need Help on Massey Ferguson Baler? in reply to Nellie, 09-19-1998 16:26:29
Nellie I read your post about a stuck #9 baler and I would like to know how you got the packer unstuck. I have a #3 that had been sitting inside with hay in it for 10-15 years and the packer is rusted tight. How did you get it freed up?
Mike Huber
09-20-1998 15:29:42
: Mike, I wrote you about my MF 10 awhile ago. I had the same problem when I bought the 10. Mine sat inside for a few years and was 'froze' up. My wife and I spent the 4th of July trying to get free. We got it loose finally and it ran good. If I disingaged the PTO it would almost stop on a dime. I kept putting oil and grease on those slides and after a couple of hundred bales it really freed up. My advise to you is just keep with the oil and grease. Don't get wild and start taking those slides apart.
: I had to store my baler outside and every spring I had to grease and oil those slides good and wait about 50 or so bales until everything started running smooth. Keep working on it and watch for improvements after disingaging the PTO.
: on my MF #9 Baler I have a proplem every thing runs like a clock The baler has been sittng for the last two years I oiled & greased every thing all up cleaned every thing up,Runs great but on the packer it rides on rails I oiled them up also But the rails are getting so hot that water will sizzle on it! I'm running at 65-70 strokes a minute there seems to be no hard friction will run at a idle no proplem What I'm I missing ? Thanks Mike Huber
Nellie: Thanks for the reply I didnt take any thing apart I'm just going to putting oil & grease on the rails it seem to be getting better I only but 80 bales thru it Thanks for adice Mike Huber
Dick Davis
10-06-1998 03:40:09
 Re: Re: Re: Need Help on Massey Ferguson Baler? in reply to Mike Huber, 09-20-1998 15:29:42
: I have a New Holland 80 baler that had been stored for 20-25 years. The bale chamber was so rusty that I couldn't make normal bales by weight or density because of the friction between the hay itself and the chamber. After 300 bales it was still not better. I bought "Slip Plate" paint from Tractor Supply Company and it worked great. It contains a lot of graphite, rolls or brushes on and dries rapidly. After this years 350 bales it still is in good shape. Dick
: : Mike, I wrote you about my MF 10 awhile ago. I had the same problem when I bought the 10. Mine sat inside for a few years and was 'froze' up. My wife and I spent the 4th of July trying to get free. We got it loose finally and it ran good. If I disingaged the PTO it would almost stop on a dime. I kept putting oil and grease on those slides and after a couple of hundred bales it really freed up. My advise to you is just keep with the oil and grease. Don't get wild and start taking those slides apart.
: : I had to store my baler outside and every spring I had to grease and oil those slides good and wait about 50 or so bales until everything started running smooth. Keep working on it and watch for improvements after disingaging the PTO.
: : on my MF #9 Baler I have a proplem every thing runs like a clock The baler has been sittng for the last two years I oiled & greased every thing all up cleaned every thing up,Runs great but on the packer it rides on rails I oiled them up also But the rails are getting so hot that water will sizzle on it! I'm running at 65-70 strokes a minute there seems to be no hard friction will run at a idle no proplem What I'm I missing ? Thanks Mike Huber
: Nellie: Thanks for the reply I didnt take any thing apart I'm just going to putting oil & grease on the rails it seem to be getting better I only but 80 bales thru it Thanks for adice Mike Huber
