Roto Tiller
Sandy
11-25-2001 19:22:04
I am looking at purchasing a PTO dirven roto tiller for a 50 hp tractor. I have found several tillers that are chain driven and one that is gear driven. I would like input on what you think is better for the long run. Brand names would be helpful.
bbott
11-27-2001 06:46:06
 Re: Roto Tiller in reply to Sandy, 11-25-2001 19:22:04
Howard is the name you want. Like one of the other posts noted, they are available with a quick-change gearbox so you can change your tine speed to match conditions.
Mine is about 30 years old and still running. The rust goblins here are finally getting it, but it still takes a licking and keeps on ticking.
Robert in W. Mi.
11-26-2001 17:17:33
third party image
I do a lot of custom Rotovateing, i don't agree that it's a first or second gear slow going tool. It all depends on what kind of tillage you are after. Some customers want the soil ground fine, others want it left similar to what a chisel plow would leave, but with smaller clods of dirt. I always ask my customer what they are after, and then make the adjustments to my Rotavator to leave the soil as they want. I wouldn't buy a Howard Rotavator with out a multi-speed gear box, because if you do, all you'll have for the most part is a HD rototiller. As for chain or gear drive: i prefer the chain drive, as Howard puts a very HD chain in there's, and in over 15 years of heavy use, i've yet had to replace one. (I have two Howards) You have a choise, buy the best Rotavator now, OR pay later when you hit something, "AND" you will hit something!! Robert
PCC-AL
11-25-2001 23:56:01
Hi Sandy,
I don't own a tiller, but used a friend's for a couple of weeks last two summers. It was chain driven and about 10 years old and still working. I think he bought it used. It worked o.k. in my freshly broken garden, but I thought it was slow. Behind my new tractor, the blades didn't seem to turn fast enough so I had to run in a very low gear with lots of rpm to let it really do a good job.
If you can, I suggest that you borrow a tiller and try it first. Maybe the dealer will let you try one out before you buy it.
Good luck.
F14
11-26-2001 02:41:33
 Re: Re: Roto Tiller in reply to PCC-AL, 11-25-2001 23:56:01
Tillers are meant to work as described: Rated PTO RPM in 1st or 2nd gear. It's what they do.
As to brands, it's hard to beat a Howard, IMHO. I've had mine for 13 years, and it's seen a lot of hard use. It's a chain drive. Keep the slip clutch adjusted properly, change the chain case oil regularly, and it'll outlast you.
