Need help with disk
Brett J.
11-25-2001 05:13:20
I don't know if you guys can help, but i would like any you have. I have a 4 foot disk that i was using to disk corn stalks last night and on the back their is pice of metal much like a lefspring for a truck and it feel of the bolt. So i was woundering what the best way to but it back on is, because ith pice has to have a arc and you can bend it by hand. any help is thanks brett J.
paul
11-25-2001 12:40:07
 Re: need help with disk in reply to Brett J., 11-25-2001 05:13:20
Springs can be pretty dangerous to work with, so I would not want to give any advise based on the little info you gave. I could end up hurting you, and I would not want to do that!
Where exactly is the spring, what does it do, is it attached with long bolts? What brand of disk is it? 3-point, wheel, trailer...
Probably have to loosen most attachment points (do not remove, just loosen) of the spring, hopefully there are long bolts involved, and get everything together again that way.
More info on what we are dealing with will really help.
--->Paul
Brett J.
11-25-2001 13:27:39
 Re: Re: need help with disk in reply to paul, 11-25-2001 12:40:07
I don't know the name. but when i whent to check it out again today what i said was a spring in the banck is not a spring it is two pices of metal that sild in and out of each other so i think that i have to sild the one pices in and get a new bolt and put it tne hole. i think it is a trailer if that has no wheels and no 3-point. if you think i'm going to do some thing wrong please let me now thanks.
