Syracuse Plow
Jeff
11-05-2001 12:21:46
I have two single bottom Syracuse walk behind plows. They both have "No.20 1878" cast into the frog. The one which I think is newer, was my Great-Grandfather's and has a small John Deere symbol (JD) cast on the frog and "Syracuse Chilled Plow Co." The other, which I bought at an auction does not have the JD and the lettering is a different style, but everything else is the same. Does anyone know anything about these plows or where I could find out about them? When did John Deere aquire Syracuse? Thanks
George
11-06-2001 06:25:58
 Re: Syracuse Plow in reply to Jeff, 11-05-2001 12:21:46
Jeff, Maybe when they answer your question they will also answer mine. I have a single bottom J.D. plow
pull type ,on the beam is has John Deere 614 and on the moldboard it has a JD symble and sez syracuse chilled iron plow co. and the mold board is cast iron and about a 1/2" thick it looks like the cut is 18" wide it's on steel wheels and is a clutch lift with tongue trip I would like to know what it was suppost to be pulled with?I pull it with a "B" chalmers and approx. how old it is.
thanks in advance GEO.
Bob Collins
11-06-2001 13:04:02
 Re: Re: Syracuse Plow in reply to George, 11-06-2001 06:25:58
George, What you have is a number 51 plow made by John Deere from 1934 through 1948. It was supposed to be pulled with any small tractor, they just wanted to sell plows, but often a B or an H was the John Deere that got the job. Your Allis B is also allowed, have fun. Bob
George
11-07-2001 06:11:42
 Re: Re: Re: Syracuse Plow in reply to Bob Collins, 11-06-2001 13:04:02
Bob, Thanks for the response, I think the "B" J.D. would not have any trouble pulling it, but it would require lighter solis for the little "H".
Now that I know it is as old as that, I should take better care of it! thanks for the information
George
