Redneckin' the plow . . .
ShepFL
10-29-2001 12:50:28
third party image
Been doing some redneckin' to get this plow useable for me. So far I have dropped underslung front hitch, cleaned it up a bit, repacked the bearings and greased her up. Next steps are 1) weld HD Cat. 1 drawbar for lower lift arm attachment, 2) weld up A-Frame to drawbar, and 3) figure out some way to add flat stock from A-frame to rear of plow for rigidity. Seeking your comments before I weld everything up.
Thanks - other pics available if needed. See>Link
OR
http://www.ytmag.com/implment/messages/26893.html for original post.
paul
10-29-2001 19:17:34
 Re: Redneckin' the plow . . . in reply to ShepFL, 10-29-2001 12:50:28
It can be very handy to be able to slide the 3-point left or right for different tractors / wheel spacings / proper draft. Are you planning on welding it all up, or are going to bolt the new 3-point parts to the frame?
Could you fit some square stock or angle iron from the hole below the upper link down & to the right, bolt it into the back hole there on the back bottom? Might take a bit of cutting, bending, & rewelding, but should make a nice strong brace. Really doesn't look like you would have to weld much at all other than that upper brace? Just some good gr 5 or 8 bolts.
Naturally you have checked for clearance from the front disk to the tractor, looks pretty close up, but should not be a problem. Need room for the dirt to turn in there.
--->Paul
ShepFL
11-01-2001 06:03:31
 Re: Re: Redneckin' the plow . . . in reply to paul, 10-29-2001 19:17:34
Paul - Have to agree that it would be very handy to be able to slide the 3-point left or right for different tractors / wheel spacings / proper draft.
Without your comment I had planned just to weld everything up for my Oliver 550. Bolting it up certainly sounds like a better alternative and also adds to the resale value should I decide to get rid of it. All new replacement hardware is 1" Grade 5 & 8.
Kind of confused by your comments "Could you fit some square stock or angle iron from the hole below the upper link down & to the right, bolt it into the back hole there on the back bottom? Might take a bit of cutting, bending, & rewelding, but should make a nice strong brace."
Pls look again at the pic and explain your reference to RIGHT. Is this when standing behind plow? Facing plow?
Naturally I FAILED to check for factory clearance from the front disk to the tractor, and I agree it looks pretty close. All I did was raise and lower the plow to make sure I did not hit the tires. I will check the dimensions tonite. Any idea on what the minimum clearance should be?
Thanks for your assistance.
Jack
10-29-2001 17:41:15
Add some weight to the top of the beams and you will have you a Dearborn 10-80. I agree with needing some bracing from the A-frame to the beams. Looks good so far.
ShepFL (Hee Hee !!)
10-30-2001 18:21:50
 Re: Re: Redneckin' the plow . . . in reply to Jack, 10-29-2001 17:41:15
I hear ya Jack! I take it your new plow is working great!! Thanks for the kind words. I still have that Oliver plow sitting in SC I need to get moved.
In the mean time I am trying to get this ground finished for winter pine tree planting. How heavy is that 10-80?
PS - Did you get my email about the manual for the 2 bottom plow? Drop me a line or call.
