JohnDeere Disc
SamMI
10-23-2001 18:04:24
Found old disc for sale. No model number anywhere on disc. It is an 8 ft tandem disc. and has travel wheels. Question is are the bearings generally available for John Deere implements. Owner says all the disc's were replaced years ago and used very little since. He couldn't or wouldn't comment on the condition of the shafts but I can move the shafts in the bearing housings.
KEVIN L
10-23-2001 22:57:38
 Re: JohnDeere Disc in reply to SamMI, 10-23-2001 18:04:24
LOOK VERY CLOSE AT OUTSIDE FRAME PARTS IF IT IS A KBA DISC IT WILL HAVE SMALL STAMPED #S ABOUT 1/4 TALL SUCH AS KBA 8 LF OR KBA 9 RR OR SIMALAR DEPENDING ON WHICH GANG YOU ARE LOOKING AT. IF IT IS A KBA, BEARINGS ARE STILL AVAILIBLE FROM DEALER FOR ABOUT 30$ A 1/2 SO ABOUT 60 A PIECE IF YOU GREASE IT UP GOOD IT WILL PROBABLY RUN GREAT FOR YOU AS IS. AROUND HERE A KBA ON WHEELS THAT SIZE WILL BRING 500 EVEN AT AUCTION. TO MANY OF US PRETEND FARMERS PLAYING WITH SMALL EQUIPMENT I GUESS.
KEVIN L
10-23-2001 22:57:22
