No. 80 Combine
Marty G.
10-02-2001 10:27:14
I have a #80 McCormick pull type combine. I used it this week-end for the first time since I bought it last year. I would like to know if I still can get cutter bar knives and guards. Because they look pretty warn and the straw was jamming in the sickle knives. Also would like to get operators manual for this beast. Lastly, anyone interested in the pick-up attachment for the same beast.
manuel
10-03-2001 15:08:36
 Re: No. 80 Combine in reply to Marty G., 10-02-2001 10:27:14
Marty,
There is an operators manual available for the 80 combine.
Marty G.
10-04-2001 06:29:23
 Re: Re: No. 80 Combine in reply to manuel, 10-03-2001 15:08:36
Thanks Manuel, I never tought of looking it up in that great site.
Roy B
10-03-2001 07:30:14
Marty I use a McCormick 64 pull type. I was able to get guards from the Case IH dealer, they had them in stock ( must fit something newer as well) The sections were a little harder to get, no one seemed to have them. The NH sections that fit my IH 990 mo-co and NH 450 mower are the same shape and hole pattern as those on the combine. I had to use a mini grinder to cut some off the wide end of the section. The sections are flush with one edge of the knife bar on the 64 rather than overhanging as one the other two machines. Hope this makes sense, and helps out. Good luck. Roy
Marty G.
10-03-2001 07:53:54
 Re: Re: No. 80 Combine in reply to Roy B, 10-03-2001 07:30:14
Thanks a million Josh & Roy for your tips.
Josh
10-02-2001 19:12:04
I have a JD 12A and this year was having similar problems. I got sections from a JD haybine and the guards work also. The John Deere dealer could get the original sections but they were much more expensive. To save more money since straw is easy to cut you might try sections and guards from a farm supply store like central tractor.
