JD 2020 loader
Duane
03-03-1999 20:20:35
Can anyone tell me what JD loader(s) would fit a JD 2020?
RickB.
03-06-1999 09:25:13
 Re: JD 2020 loader in reply to Duane, 03-03-1999 20:20:35
The following list is incomplete, but is a start: #37,46,48,146,148,245. most any JD loader you find used with "Utility Tractor Mounts" will fit. Most of the loaders I listed were also found on Row-Crop tractors, and those mounting parts are not interchangeable with utility tractors.
Gerald
03-04-1999 07:28:59
My neighbor's 2020 has a JD 46 loader. I suspect a JD 146 may also fit. Depends on brackets. Lots of loaders will fit if you are willing to make the brackets. Last summer I mounted a MF-236 loader on my JD-4020. Welding shop cost me $304 for welding brackets. Works fine.
Gerald
