Need to ID old bush hog
T.J.
09-20-2001 09:14:42
I am fixing up an old bush hog that my brother got with his tractor I havent measured it yet but I believe its around 4 foot, it is a 3 point with 2 small casters on it the gearbox says AGMO made in USA and 45 I guess its a 45 horse gearbox. It is ford blue now but there is a redish orange color coming through I was wondering if it was an old Howse.I think I can cross reference the blades and blade bolts out of the farm and country catalog I also need the bottom oil seal for the gear box but it can probably be found at my local supply house. Thanks, T.J.
Joe ks
09-20-2001 16:06:51
 Re: Need to ID old bush hog in reply to T.J., 09-20-2001 09:14:42
Tom, the Howse Bush hogs are a division of AGMO USA or maybe Agmo is a division of Howse. anywho, that is a very good starting point. Good Luck
Joe ks
09-20-2001 16:06:31
Tom A
09-20-2001 12:21:10
Sorry, I can't help directly because I have lost my list of hog manufacturers, but I went through the exact same thing two years ago. I will share with you what I did--took about 3 hours on the phone and I learned a lot about -hogs.
1st, I don't think yours is a Howse because their gear boxes are labelled HICO (For Howse Implement Company.) But that still might not be a bad place to start because they were helpful.
Find the number of a bushhog manufacturer (I searched the net to find a list). Call one and explain what your are trying to do. They'll ask questions about the particulars of the hog like "Does it have 1 inch or 2 inch angle iron on the framing?" Then they'll send you to the guy or guys that they believed made the right one. Most were very friendly and helpful when I went through this--it apparently happens fairly often.
I posted a list of numbers and names on this board at the time I did it, but I couldn't find it just now when I searched the archives...must have been too long.
Good luck. If I run across my list in the next few hours I'll post it again and email it to you.
Tom
