Massey ferguson dynabalance sickle bar mower.
old fart
09-15-2001 11:17:30
Hi neighbours, as well as my Deerborn Mower I have now been given a Massy Ferguson Dynabalance Sickle Mower. It has a broken crank shaft though. There is no model number in the plate. I would like to get a new or used crank shaft and a manual on this beast, any suggestions. thanks
rem
09-18-2001 18:00:41
 Re: massey ferguson dynabalance sickle bar mower. in reply to old fart, 09-15-2001 11:17:30
I've had good luck getting parts for mine at the Massey dealership.
JIMVA
09-16-2001 17:57:27
if it has no model number on the plate and the gear box is cast iron and not a welded gear box then the mower is a MF 31. the only way to tell the difference between a 31 and 41 is by the gear box. a 31 has a cast iron gear box with no angles, the 41 has a welded gear box. the 31 is a damn good mower i have one and i have never had any problems with it.
Tim(nj)
09-15-2001 19:43:41
Is the crank housing cast as one piece, or fabricated with pieces of welded plate? Is it full 3-pt mount, or is it mounted on the stabilizer pins with the 3-pt. connected to a large spring to lift it?
old fart
09-16-2001 18:21:18
 Re: Re: massey ferguson dynabalance sickle bar mower. in reply to Tim(nj), 09-15-2001 19:43:41
Thanks for the info guys. Yes it has the cast gearbox and the large spring on the lift mechanism so it would appear to be a Model 31. I have received some mail from another fellow who has the manual on this beastie but I still need a crank shaft or the mower is useless.Help.
Tim(nj)
09-17-2001 13:59:20
 Re: Re: Re: massey ferguson dynabalance sickle bar mower. in reply to old fart, 09-16-2001 18:21:18
I have a Model 31, and parts for the balanced head drive are obsolete. I found a spare crankcase assembly in a salvage yard. You'll likely have to do the same.
