Tree Stumps
Pitch
09-14-2001 07:48:56
I had about 15 0r 20 Black Walnut stumps that I needed to take out of my new building lot I rented a Bobcat325 Mini-excavator and went to work I got all but two big ones but the machine was really struggling what are my options on the other two short of hiring a full sized excator in?
Bill
09-22-2001 16:28:03
 Re: Tree Stumps in reply to Pitch, 09-14-2001 07:48:56
If you have a stump it's too late now. In the future, consider this. I have put too many final drives in dozers picking at stumps. Tore up a decent back-hoe. Nowadays I got an old straight frame inexpensive payloader. As long as the tree ain't dead & theres no worry of getting killed from falling limbs, I bring the ole payloader over, hit the tree at about 6-7 feet up with the bucket & between the lift & the push the old girl generates, tree falls over. THEN I cut it up....
ferrell freeman
09-14-2001 18:29:09
I, the same problem with large oak stumps .I,rented a 428 cat backhoe /loader from the from RING RENT A CAT DEALER and made short work of stumps and filled allthe holes leveling the ground.
Ol Snuffy
09-14-2001 16:32:07
The other two posts are both good advice. Here is another alternative. Bild a fire on top of the stumps and burn them into the ground. We don't have any walnut trees here but I have burnt a many red fir stumps out by putting a 55 gal. barrel with both ends cut out, over them and building a good fire in it. It usually takes a couple days but it does not cost much either. It will work just fine. Hope this helps, Snuffy
bob
09-16-2001 14:56:24
 Re: Re: Tree Stumps in reply to Ol Snuffy, 09-14-2001 16:32:07
we had a big elm tree and used charcoaal to keep it burning didn,t use barrel but is good idea even if to keep from burning house or buildings down
bbott
09-14-2001 12:41:34
If you are going to be digging foundations and such in there... I'd get the bigger machine in, dig 'em out and be done with it.
Be aware you are gonna have some craters left and will need to re-grade anyway so you might get somebody who can do it all at once.
Depending on size/rootstock grafting etc, those black walunut stumps could be worth some money to the hardwood people. Might pay for the job.
They use them for fancy gunstock blanks and such.
Just 2 cts worth here.
-- bb
Mark A
09-14-2001 11:28:33
Would a stump grinder work for you?, especially in conjuction with your machine. I saw an add somewhere not too long ago for one, but have been unable to find it. Maybe someone else can give that to you.
