Strieght hole with a post hole digger
Jay
09-12-2001 13:06:35
How does one dig a streight hole with a post hole digger? Mine keep curving toward the tractor.
Steve
09-30-2001 11:53:13
 Re: Strieght hole with a post hole digger in reply to Jay, 09-12-2001 13:06:35
If its on a backhoe make sure your extended out 1/2 way or so then all you have to do is boom in or out. Some guys w/try to find a area on the drill head where they can strap a torpedo level or round level type so they can see it from the cab. hope it helped.
Kermit
09-14-2001 01:42:35
Set the auger point on the ground where you want it and then pull forward a little bit. That way when the auger goes down it will tend to straighten up. If it goes at angle you can always pull forward or back up as needed like F14 suggested.
F14
09-12-2001 13:37:51
Perfectly straight is near on impossible, at least in my experience, and I've dug a few.
I do find that after digging the first foot or so, I need to inch the tractor forward a bit to keep the auger vertical. As the boom lowers, it describe a slight arc, which causes the hole to angle toward the tractor if you don't compensate for it by moving the tractor.
Festus
09-12-2001 18:17:36
 Re: Re: Strieght hole with a post hole digger in reply to F14, 09-12-2001 13:37:51
F14 is correct. I leave the brake on and slightly move forward a couple times to get the holes straight.
