JD disc blades
Steve (WI)
08-30-2001 15:04:43
I have an old 8' JD disc in dire need of new front disc blades (16 of them). The blades ride on a 7/8" shaft. The local JD dealer said he couldnt' help me with one so old (7/8"). The smallest disc/shaft size I have thus far found is 1 in. Any suppliers for a 16"disc with a 7/8" shaft?
I thank you in advance
Steve
Hal
08-30-2001 20:18:51
 Re: JD disc blades in reply to Steve (WI), 08-30-2001 15:04:43
Are you sure they were 16" originally? I would go with 18" if they fit the frame, it should be no problem. You can still find them with a 7/8" hole, these were used on some MF 3pt disks, and others. Watch the thickness, 9gauge, 11 gauge etc. If you use thicker, you may run out of threads on axle. 9 gauge, 18" is good on a disk that size. There was a guy name Stu who offered disk parts here from time to time, I believe email was [email protected] .
Leroy
08-31-2001 05:23:21
 Re: Re: JD disc blades in reply to Hal, 08-30-2001 20:18:51
use the 11 gauge(orignal) other wise you will run out of threads, 9 gauge is for newer disks
paul
08-30-2001 16:55:24
Sloan Express or Shoup specialize in disk parts, shafts & bearings as well. I bleive Shoup is the one. Should have an obvious web address by now...
--->Paul
Steven M
08-30-2001 15:48:39
Try Wiese 1501 Fifth St Perry,Iowa 50220 (515)465-9875
Jerry D in NC
08-30-2001 15:42:44
Sure, Agri Supply has them in both 3 and 3.5 for the 7/8 square/1" square axle combination for $4.50 and $5.52
Part Number 25795 and 39296
Look under "Tillage" in the catalog
