Post Hole Digger
MLCLARK
08-29-2001 16:55:12
Can someone out there tell me is there a easy way to connect a post hole digger to the tractor. I am new to tractors and this seems to be a very diffecult connection to me.
noff
08-31-2001 08:46:19
 Re: Post Hole Digger in reply to MLCLARK, 08-29-2001 16:55:12
I keep mine in a whole I dug with the auger about 1 1/2 feet deep. It makes life pretty easy for hooking up and unhooking. not as easy as hanging it from a tree. Now that sounds nice.
rhudson i'm with Burrhead
08-30-2001 18:56:49
i have one i made from a car rearend and 3 inch pipe, its way too heavy. welded a lifting ring near the balancing point and hang it from a limb. i use a chain with a chain hook for quickness.
Phil (VA)
08-30-2001 10:45:13
Always connect the middle connection first, the one that goes to the point where the top link would normally attach. Then connect the other two points. Doing it that way will allow one man to do it without lifting it, etc.
Burrhead
08-29-2001 21:07:07
I keep mine hanging on a rafter in the shed. That way I don't have to wrestle it on and off.
It's a lulu the 1st hookup if you're alone, but once you have it mounted.
When you get ready to unhook just pull under a tree limb or whatever and raise the lift all the way up, now tie the auger up tight with good heavy rope or chain and let the pressure off your 3 point, now unhook the arms and next time will be a snap.
