Lift Arm Keeps Bending
VP in SC
08-27-2001 12:13:54
The controlling lift arm on my '69 Ford 2000 broke last year while using a 5 foot disc harrow. I thought it was just normal wear and tear, so I bought a new one and went on about business (mostly bush-hogging since then). I put the harrow back on a couple of weeks ago and after only about an hour of use, I noticed the new arm had a significant bend in it. I've got stabilizer bars installed. I took it off and straightened it, but the bend was back after only about ten minutes of work.
Anybody have any idea what's making it bend? I've checked it against a similar tractor side by side, and don't see anything obvious. The other (Left) arm doesn't seem to have any flex in it at all. Nothing seems to be binding, and the disc harrow seems to be adjusted correctly.
Dave C
08-28-2001 09:58:16
 Re: Lift Arm Keeps Bending in reply to VP in SC, 08-27-2001 12:13:54
Are you turning at the end of the field with the disk in the ground? You've got to raise a disk before turning or damage can result as it tries to skid around the corner on a turn. This is especially true for a 3 point disk as it is ridgidly attached to the tractor and has less "give". If you usually turn the same direction, this could be the reason the same arm always bends.
Phil (VA)
08-28-2001 08:02:35
If you back into something with an implement installed they will bend much quicker than any other way I can think of. Like if you have a blade installed and push gravel backwards, etc. Could you be bumping something in reverse? That's only thing that comes to mind.
Duane(Pa)
08-27-2001 18:59:46
My ford arms are Junk I had the local weld smith put a plate on the bottom of mine (full length) so they effectivly have a "T" shape cross section
