Leveling Land with a Box Scraper Technique?
Rick from Paso
08-26-2001 23:09:41
Have a box scraper hooked up to my old Case 310B with a home-adapted 3-point hitch that works well on roads. I am trying to level a spot for a pole barn and having a heck of a time trying to level it out. The land is gently sloping into a bowl, I have to fill the center area but everytime I scrap up a pile, the scraper digs in and stops the tractor. I end up with piles everywhere and trying to smooth it backout is driving me nuts! The front wheels hit the pile and force the scraper down and it digs in. Whats the trick?
Thanks for the Help! I'll give'r a try
08-27-2001 22:30:55
 Re: Leveling Land with a Box Scraper Technique? in reply to Rick from Paso, 08-26-2001 23:09:41
My box scraper does have a back blade, haven't really used it much. The ground here is very dry this time of year, that's part of my problem, it doesn't really pack. My 3 point is very responsive so I'll try harder to work the thing. Thanks every so much for the pointers!
Regards, Rick from Paso.
Jason - Senoia, GA
08-27-2001 18:53:49
Rick,
Grading with a box blade can be tricky. As the other two fellows said, it requires a smooth hand on the lift control. Also, it helps if the soil is not too wet or dry - similar to plowing. A very important adjustment is the top link - shorten it to make the blade dig deeper (while moving forward), lengthen it to feather out piles without digging in. Another thing: once you have the "rough grading" done, use a higher gear and make circular passes with a very light touch to fine grade right down to the point where a few minutes with a garden rake will make it look perfect.
John in Abq
08-27-2001 09:43:50
Rick, How responsive is your 3PH? If it has any lag in it then the whole operation gets tricky. As your front wheels start to climb then you need to be moving the 3PH lever quick enough to keep up with the front. Also doing a lot of back blading is just part of life with these beasties.
One thing to try is after you have pulled up some hills is to go around and come down the hill using the 3ph to raise the blade and feather out the cut. The previous cuts will be loose and eaiser to work.
The main thing is not to work too deep at once. Pull up some dirt, rough level it and go get some more dirt. You probably should figure on layers about 4-5" deep at a time.
It's kind of hard to explain. Maybe some one else can jump in and say it better.
One more thing, once you get a layer down, drive all over it to get it packed before adding the next layer.
HTH John
BB
08-27-2001 04:59:15
Some box scrapers have a blade on the back for pushing dirt going backwards. This is the easiest method of leveling piles of dirt. If yours doesn't have a back blade, it is tricky. You can raise the scraper, back up to a pile of dirt, drop the scraper on the pile, and drag the dirt out a little at a time. You just have to go slow, keep your hand on the raise/lower lever, and constantly adjust it as you move over the uneven areas.
