Tiller for Super C
Rob in Wis.
08-20-2001 19:47:53
I've been thinking about getting a gear drive tiller for our small vegetable farm. I've got a Farmall Super C. Most tillers I've seen come in 4, 5, & 6 foot widths. The 4 footers are usually off-set to one side to cover one set of wheel tracks. The recommended horse power for the 5 footers usually say it should be run from 25 - 35 hp. My SC has 24 hp. Now the questions... is there enough cushion in the recommendations so that I could handle a 5 footer? Anyone have experience with the 4 ft. off-sets? Do they work OK?
gnelllist
08-21-2001 12:16:49
 Re: tiller for Super C in reply to Rob in Wis., 08-20-2001 19:47:53
Unless you have the creeper gear in the Super C, your first gear probably would not be slow enough for effective tilling. Also, the Super C does not have live PTO so you can't stop the ground travel and have the tiller keep going.
I can't help you on the horsepower question.
Rob in Wis.
08-21-2001 18:14:21
 Re: Re: tiller for Super C in reply to gnelllist, 08-21-2001 12:16:49
I was planning on using an over-run clutch on the PTO to deal with the ground travel issue. I hadn't thought about the speed issue in first gear. I don't have a creeper gear. Has anybody out there tried a tiller in first gear?
SAO
08-23-2001 15:11:27
 Re: Re: Re: tiller for Super C in reply to Rob in Wis., 08-21-2001 18:14:21
I've been around super c's. Their first gear isn't low enough I think you'd be disappointed.
With a tiller you need to creep, but have full rpm's. The only way it would work if is the ground was already plowed.
Rob in Wis.
08-25-2001 18:57:33
 Re: Re: Re: Re: tiller for Super C in reply to SAO, 08-23-2001 15:11:27
SAO: The ground is in vegetables this year. I plan to plow and disc, and if feasible, then use a tiller to prepare 4 ft. beds for planting. Based on that, is it still too much to expect the C to be able till effectively in first gear?
SAO
08-26-2001 06:03:45
 Re: Re: Re: Re: Re: tiller for Super C in reply to Rob in Wis., 08-25-2001 18:57:33
I think it would work. I didn't realize you were going to work the soil before hand.
Rob in Wis.
08-26-2001 19:10:30
 Re: Re: Re: Re: Re: Re: tiller for Super C in reply to SAO, 08-26-2001 06:03:45
OK. I'm going to give it a go. I appreciate your willingness to discuss this with me.
