Pick-up cam adjustment needed?
Colin Mill
08-16-2001 15:10:41
I've been trying to check out my NH Super 68 baler so that I'm ready to go when (if!!) we get the weather. I've only been able to try picking up some fairly damp stuff and much of this gets pulled down between the pick-up guards. Is this simply because its not eating decent hay or can I expect it to do the same with correctly dried hay? I notice that the manual mentions an adjustment of the pick-up cam to cure feed problems of this type but I don't want to do this if it will be wrong once I get going for real.
Thanks
Colin
Burrhead
08-16-2001 15:30:32
 Re: Pick-up cam adjustment needed? in reply to Colin Mill, 08-16-2001 15:10:41
Colin it could be because the grass is still too green, but even with green it should spit the grass out onto the feeder tine chamber.
Colin Mill
08-17-2001 11:51:30
 Re: Re: Pick-up cam adjustment needed? in reply to Burrhead, 08-16-2001 15:30:32
Hi, That's interesting, it seemed to me that it got the stuff rather firmly jammed into the top of the slots and seemed to be stopping further material from getting where it needed to. Perhaps I should try the cam in the second position anyway. At least that way I will know what it takes and have unstuck the bolts!
Many thanks
Colin
