JD 1219 Haybine, trouble with wobbler box
Terry Ishmael
08-15-2001 09:17:20
I bought a JD 1219 haybine last winter at a consignment auction. I soon found out why someone sold it. The first time I took it out, it stripped the 4 bolts that hold the wobbler box on. I took the box to a machine shop and had the bolt holes drilled and tapped for 3/4" (the originals were 5/8"). I mowed for about half a day and 2 bolts sheared and the other 2 broke out the corners of the box. The sickle is loose enough to move back and forth by hand and not hitting anywhere, so I don't know what's putting all the strain on the box.
I found a salvage yard that has the housing for $150, or the whole box for $450, but I hate to buy anything until I know what caused the problem.
Anyone had this problem, or know what the cause may be?
Jasonbogli
03-24-2006 11:55:52
 Re: JD 1219 Haybine, trouble with wobbler box in reply to Terry Ishmael, 08-15-2001 09:17:20
sorry to hear about your problem. I also bought a 1219, a need to replace the forming shields. Does anyone know a place that has these parts ?
Tim(nj)
08-15-2001 17:59:21
I have a 1209 which has a similar wobble drive. Sounds like the wobble box is out of balance and is vibrating itself off its mounting bolts. Check with a JD dealer to see what having the box rebuilt costs before you get one out of the salvage yard.
