Is a Bush Hog a pasture topper?
Colin Mill
08-13-2001 15:26:20
I've been reading the messages about using a "bush hog" for hay conditioning. I think the Bush Hog is what we in England call a pasture topper but I'm not sure. Basically the topper is an overgrown rotary mower with two flail blades pivoted at the ends of a rotor bar (total diameter about 5 or 6 ft). Is this the same thing as a bush hog? I've been trying to work out which side panel to remove. Mine rotates clockwise (viewed from the top). Thanks
Colin
sammy the RED
08-13-2001 22:18:55
 Re: Is a Bush Hog a pasture topper? in reply to Colin Mill, 08-13-2001 15:26:20
Bush Hog is a brand name of a implement manufacture. A lot of people misuse the name to describe a rotary cutter, such as a pasture topper.
paul
08-13-2001 18:31:20
Sounds like the same thing. :) Burrhead (I think) had some good advice a few months ago on making hay with one.
--->Paul
john2510-3020
08-13-2001 15:55:54
a BUSHHOG is a rotery type of deal it has 1 blade up to 3 blades and as narrow as 42"(finishmower) to as wide as 20' here, heres what one looks like go to heavy lift cutters and you will see a pic.of one.....
john2510-3020
p.s if i doesnt come up here there address www.kingkutter.com.....
john2510-3020
08-13-2001 15:54:42
john2510-3020
Colin Mill
08-14-2001 13:25:32
 Re: Re: Is a Bush Hog a pasture topper? in reply to john2510-3020, 08-13-2001 15:54:42
Many thanks to you all for the info. Hopefully I'm all set to make hay - all I need now is the weather (always in seriously short supply over here!)
Thanks
Colin
