JD sickle mowers
Ed
08-10-2001 13:35:26
How many different models of sickle mowers did JD make and which ones would fit a late B? Also, any good links to pics to see the difference between them?
Joe R
08-27-2001 15:24:52
 Re: JD sickle mowers in reply to Ed, 08-10-2001 13:35:26
The #37 is a good one, and still easy to get all parts for using one today as a matter of fact. Good luck. PS keep it sharp and the gards in good shape.
ZiggyStardust
08-10-2001 18:37:31
Ed,
The #5 mower was made during the "B" era. There were alot of #5 mowers made, so finding one shouldnt be too hard. They are a very good mower. I use one behind my '49 A. Some other pull type mowers would be the #8 or 8W(the W meaning wide for wide tread tractors), and the #37 ( I think). If you have a 3pt on your B, some mowers to consider would be the #9 or 9W, #39(again I think ), and the #350 mower. Any of these should work on your B, and all are pretty good mowers. Good Luck
Ziggy
Ed
08-10-2001 18:47:28
 Re: Re: JD sickle mowers in reply to ZiggyStardust , 08-10-2001 18:37:31
Thank you very much Ziggy. Just bought a #5 in great working condition for $100. Appreciate your response.
Dan
08-12-2001 17:19:30
 Re: Re: Re: JD sickle mowers in reply to Ed, 08-10-2001 18:47:28
The #5 is a great mower and shares some parts with the later #8. Will work well as long as sickle is sharp, rock guards adjusted, lead and register is set right. I suggest you get an operators manual and parts book for it from JD. really helps to keep it working right. Then you just have to get the right mounting. On the b I would imagine the "quick tatch" was available. In the parts book for the #5 it shows brackets for attaching them to most JDs of the era as well as most other makes of tractor.
