International 990 Haybine
Carp
08-05-2001 12:52:12
Does anyone have any experience with Internation 990 Haybines. I would like to get all International Equipment to farm with, but I don't know if the International Haybines were any good, and what exactly to look for. Any help would be appreciated.
Tom from Ontario
08-07-2001 20:24:14
 Re: International 990 Haybine in reply to Carp, 08-05-2001 12:52:12
Keep the knifehead VERY tight and well lubed. If it is worn and/or loose, it will start to pound and you will have a broken knife. EVERY 990 I have ever seen has had this problem and that's from over the years working at an IH shop, JD and New Holland shops when the 990's were nearly given away to get something else.
Roy B
08-07-2001 10:28:50
Carp I just finished mowing for the second year with my 7' 990. I got it cheap and it works quite well. It seems to take a little more power to run than the NH haybines I have used, but runs fine with as little as 32 hp. I am not a big IH fan, and I have been told the 1190's are not very good but I am very happy with my old 990. It will mow clean at speeds of close to 5 mph, which is too fast in my rock infested fields. Hope this helps. Roy
Big Jim
08-06-2001 12:48:05
I had an IH 990 9' haybine for about 16 years. They are a low cost machine and will cut well. They aren't quite as nice as the New Holland machines, but then again you won't pay as much. The 990's are fairly simple to fix and there are enough of them around so parts are available.
john2510-3020
08-05-2001 16:36:21
YES! the ih 990's are excellent haybines! i have 2 now but used to have 3 until i hit a large stump and bent it so the cahin wouldnt run straight and popped off. i poll both of mine with a d-17 2510 3020 and a 200 allis i have also pulled my 9 footter with an 826 ih. i have always heard teh 1190's where junk not sure on that....my uncle has routinly mowed a little over 100 acersa year with his since new in 1976 it finally quite him last year from metal fatique. we gave $400 for a 7' and $1000 for the 9'. i have a chance to buy another 990 but i havent gonew to look at it yet. sorry to be so long winded.
john2510-3020
