NH 271 Knotters vs 273
Karl Covert
08-02-2001 10:23:58
I have found a NH 271 baler in a salvage yard. The knotters look good. Can the be put on a 273 baler?
Thanks
ernest
08-02-2001 11:54:40
 Re: NH 271 Knotters vs 273 in reply to Karl Covert, 08-02-2001 10:23:58
why do you want to do this? is there something wrong with the 273 knotters? the basic knotter is the same but probably the mounting brackets will need to be changed, not always an easy job, trial and error to get the shims correctly spaced between all the items on the knotter shaft and fit between the mounting brackets. personally, i would fix the existing 273 knotter unless there is a broken knotter frame or worn cam gears or the like. if the current knotter is just not tying well, it probably could be fixed with a new knife arm and a couple of adjustments to the twine disc spring, and twine fingers.
