NH Bale Wagon
Craig
07-29-2001 19:03:22
Can anyone tell me anything about a model 1000 (i think) NH bale wagon? It has a single axel, is two bales wide, has only two hyd. levers, and hold roughly 56 bales. I got if for $1200. It hasn't been used, in a while but the owner said he is the second man to own it, and he didn't use it much. Was working fine when he parked it. (Where have I heard that before)
garry
09-03-2002 20:33:20
 Re: NH Bale Wagon in reply to Craig, 07-29-2001 19:03:22
i had two of them sold one and id sell the other one if i had a chance,it wont pick up bails worth a dam,and the stacks always fall apart when pulling away, even if you chain them,the best way i found is i invite a hole buch of kids for the weekend for hay rides, little do they know,ha ha ha, but hey it works for me,at least the bails get home in one piece, good luck
paul
07-31-2001 02:32:07
Does it tilt back & stack, or unload the bales one at a time?
Only complaint I've heard is that with the single axle they bounce in the field a lot more than the bigger wagons with tandems.
--->Paul
Dan
07-30-2001 12:13:03
I remember a 1010 bale wagon. It used the tractor hydraulic system to operate the bale wagon hydraulics. I think the lift on the bale pickup was a windless setup with a rope you tightened up on to lift it. Think it was about like you described. Think I only say one around here and taht it worked ok as far as I know. You had to have adequate hydraulics on the tractor to run it though. Was a low cost alternative to hauling hay versus a 1032 which was the other pull type or the larger self propelled variety
DanCo9
09-08-2001 20:34:30
 Re: Re: NH Bale Wagon in reply to Dan, 07-30-2001 12:13:03
I just bought a 1010. It has a pto driven hyd pump, so I think the one you remember was probably an early model, or the 1000. My 1010 unloads either singles or stacks.
