What make/model sickle bar mower
buck
07-28-2001 20:51:17
I have begun to look around for an older(less expensive) mower to mow the roadway edge with and need one that will operate at about 30 to 45 degrees. I understand that I will probably have to fabricate (mechanical or hydraulic) to hold it in that position with. I understand that there was an older pitman arm that would do this but the dealer who gave me the info didn't know . thanks muchly
Moose
07-30-2001 20:50:27
 Re: What make/model sickle bar mower in reply to buck , 07-28-2001 20:51:17
I've been using an MF model 41 for years to mow nearly anything, anywhere. I even set the sickle up at 90 degrees and trim the hedge rows. Mowed my yard today with it, as a matter of fact. Uses very little tractor fuel and cuts under, around and over. Just keep the break-away more loose than you'd like and it will do the work you need. Should be able to pick one up for $500 to $750 in good shape, I would guess.
paul
07-30-2001 08:28:15
Most road ditches are fairly gradual and the mower won't have that much angle relative to the tractor?
However, for that angle, just spend a bit more for the belt drive wobble box, a pitman that works long & reliably at those angles is rare & probably just as expensive...
--->Paul
Joe
07-30-2001 08:20:00
 Re: What make/model sickle bar mower in reply to buck, 07-28-2001 20:51:17
If you get a Massey sickle mower, be prepared to repair it, I have a model 31,, and my neighbor does as well, we swap stories of what we have had to replace and repair,,,, but for small sections, they work OK,, just mowing 30 acres, takes a lot out of it.., if I could afford it,, I would get a disc mower.
A Kramer
09-27-2002 18:48:43
 Re: Re: What make/model sickle bar mower in reply to Joe, 07-30-2001 08:20:00
I have a Massey Ferguson, Model 31 and I need replacement parts. Where do you get your parts from? Any help would be appreciated.
Thank you. A. Kramer skittes @msn.com
ted
07-29-2001 21:13:39
Get a Massey sickel and forget the pitman arm. It would probably work better on that much of a angle. (belt drive to the shaker box)
