Wobble question
Warren
07-27-2001 11:54:34
Been reading about haybines in here and wonder about our NH479.
How do you know when a wobble is going bad, is there anything you can do to head off failure?
I have noticed a different "sound" from last year it seems like a deep knock, but it is only there when the pto is engaged and the tractor not moving.
It doesn't follow a rhythm, kind of jumps around.
One other thing, does anyone know where I can get one of the c-clip type lock pins for the pto collar? I mangled up the last one and don't want to try another "new" replacement peining kind.
Thanks,
Warren
Big Jim
07-30-2001 06:36:07
 Re: Wobble question in reply to Warren, 07-27-2001 11:54:34
Warren,
The key to heading off wobble drive problems is good cutter bar maintenance. If you cut a lot of hay you need to replace all the guards and hold downs every couple of years. Also if your cutter bar is bent uneven in spots you need to straighten it. You should be able to pull your sickle out easily. If your sickle sticks and you have to pound on it to get it out, then your cutterbar needs straightening. Binding anywhere in your cutter bar puts additional stress on the wobble box which results in premature failure. If a wobble box is making abnormal noise, chances are it's already too late. Rebuilding them is just about as expensive as buying a new one.
rhudson
07-30-2001 06:32:03
Hi Warren, i would check out the different noise. check your operators manual, i can't remember the exact specs. on the wobble. but it has six bearings that have to have a certain preload to function with a long life. if you have lost this preload and the bearings are loose and the noise if from slapping, it will not last long. as you already know the design is brilliant but expensive.
