NH 479
Rich G
07-26-2001 09:50:31
I found a good one with good rubber and a brand new wobble box on it for $1675.00. Also has a new sickle and chains. Is it worth it or should I hold off. He was asking 1800.00????? ?????
RickB.
07-26-2001 14:55:41
 Re: NH 479 in reply to Rich G, 07-26-2001 09:50:31
I would take a good 479 or 488 over a 489 in similar condition. If you need a haybine, you should grab that one. Set the header as light as you can & still get a good even cut, and you'll be happy.
vkg
07-27-2001 15:20:06
 Re: Re: NH 479 in reply to RickB., 07-26-2001 14:55:41
Rich, I have a N/H 489 haybine that I have used for 5 heavy cuttings of grass hay it gets bound up every once in a while I noticed your comment on the 489 is there something I should know about this mower? Im kinda knew at this hay making venture Thanks VKG
Warren
07-26-2001 15:22:53
Rick,
What do you mean when you refer to the header?
We've been using a 479 for 4 years and it has worked great, but I'm curious if it just has a different name than I'm used to. By the way, how do you know if the wobble, does it make more noise, or is there something to measure?
Thanks,
Warren
Sam (MO)
07-26-2001 11:41:32
Rich
I bought a NH 478 this spring, good rubber and wobble box is in good shape. All in all good condition for $2500, if you want my opinion I would say go for it. Good luck
Sam
