Oliver Disk Comments Pls
ShepFL
07-24-2001 13:31:54
Any comments on this Oliver disc harrow? Adjustable - doesn't appear so, model unknown to me, looks kinda light.
HOWEVER, I am looking for a something other than the 6' piece of junk I have now. I am considering this one. Tired of begging to use my buddy's 10' down the road.
Been unable to locate a decent 8-12' here in N. FL. This one is 8' wide with 4 gangs of seven 16" discs.
Relatively close to pick up over a weekend.
TP in Central PA
07-24-2001 13:51:47
 Re: Oliver Disk Comments Pls in reply to ShepFL, 07-24-2001 13:31:54
That Oliver disk looks more like a collectable item to me than a disk you pull into a field with. I used to use a JD disk almost nearly identical to that Oliver and as you said it was to light to do much good without making 500 passes over the field. I used the JD for a couple of seasons then I went and bought a #37 IH wheel lift disk and it works like a charm.
Just my opinion
