Plow Share
Ferguson 2-bottom
Sid
07-21-2001 10:53:12
I'm embarassed to say that after much searching and scraping I find I am looking for a replacement plow share for a Ferguson plow, not a Allis Chalmer as originally thought! The plow is a 3-point, 2 bottom, type#14-AO-28, serial# 94595 and AC-80003-C is stamped on the frame. The plow share itself is stamped 14AC-AO121. Are replacement shares available??? Thanks, Sid
Phil (VA)
07-23-2001 12:43:33
 Re: Plow Share - Ferguson 2-bottom in reply to Sid, 07-21-2001 10:53:12
Sam is correct that KY-Tenn might be able to help you. I know they have the moldboard for that plow. Also, I found a share for that plow at Dubberly Tractors in Chester, VA, phone 804 748 9815. They had a used share which was much cheaper than KY-Tenn, but they might require you look for it yourself as their used stuff doesn't appear to be cataloged. If you find a landside for that plow, let me know where, please, as I need one. Thanks.
Tom-Pa
07-24-2001 04:11:09
 Re: Re: Plow Share - Ferguson 2-bottom in reply to Phil (VA), 07-23-2001 12:43:33
Phil,
If you are looking for the rolling landside,(the rear steel wheel), Try Dale Reesman at 724-495-7172. he is closed wed and sun. hours are 8am to 12noon eastern time. (Western Pa.)
Sam
07-23-2001 07:15:26
Call 1-800-459-8366 and ask for Ken. Kentucky-Tennesee Tractor Parts. They are very helpful. HTH
