Loose knots off Ford 530 baler
MARK A. REED
07-11-2001 06:34:41
I have aproblem with the one side of the Ford baler, the knot is usually not tying, occasionally tying a knot, but once you pick up the bale the knot lets go. Very rarely the knot is good. Any help would be appreciated. Thanks.
Jerry D in NC
07-12-2001 20:06:58
 Re: Loose knots off Ford 530 baler in reply to MARK A. REED, 07-11-2001 06:34:41
Mark, I have a 530 baler and will be willing to help what I can. Do you have a manual? Go to the FNH web site and order one ASAP. The baler more than likely needs the twine fingers adjusted (aka Tucker Fingers) If they are not going back far enough one twine will slip off the bill hook as the knot ties. It will cut the twine and look good but fall apart at the first sign of pressure. If that is the case then you need a manual. Are you still using the same type of twine?
Mark R.
07-13-2001 04:22:18
 Re: Re: Loose knots off Ford 530 baler in reply to Jerry D in NC, 07-12-2001 20:06:58
I do have a manual and I think I've got it all set up correctly..... (that's what is frustrating). It appears to me that the bill hook is severly worn allowing too much of a gap in there, allowing the twine to slip out. I have a new finger on there so I'm pretty sure it is not the finger. I appreciate all the input. Thanks, Mark
Dan
07-11-2001 21:26:17
also check the tension on the twine at the twine box. has to have some but not too much. There are also sometimes different bill hooks for these depending upon the type twine you are using so make sure they are thge same
Farmer-Gene
07-11-2001 19:15:50
It's hard to say what's wrong without looking at it. A manual would be very helpful so you could go thru the whole system. I would start by making sure the wiper arm contacts the bottom of the knotter when it ties -- also check the tucker fingers. They are on top of the bale chamber below the knotters, and should clear the needle by 1/32 to 3/32-inch. When they're in the resting position, they should be from 1/8 to 1/2-inch to the left of the needle slot while the top of each finger is held toward the left. Hope this helps!
P-B
07-11-2001 17:56:20
My NH 65 baler will only tie properly when it has the 9000 plastic twine in it. Anything else will not tie properly on one side.
I 'm not a believer
07-11-2001 20:29:28
 Re: Re: Loose knots off Ford 530 baler in reply to P-B, 07-11-2001 17:56:20
bull
P-B
07-12-2001 18:28:26
 Re: Re: Re: Loose knots off Ford 530 baler in reply to I 'm not a believer, 07-11-2001 20:29:28
Yes- We do have a bull. Funny you would ask about that when we are talking about balers. Anyway, he is a nice Black Angus. We have cows too and some calves. Nice of you to ask.
Sam
07-11-2001 17:23:49
New holland uses the same knotters. I had the same problem on a NH 275. I tried everything and finally an old baler mechanic told me to switch the knotter assemblies from left to right and right to left. BINGO the problem dissapeared. Baled about 5000 more bales that year with no more of the same problem. Good Luck.
Ken Goth (MO)
07-11-2001 09:36:35
I use a JD 24T but the theory should be the same. Check your manual for the adjustments to the billhook tension. It sounds like the billhook is not holding the twine tight enough while the knot is being tied.
Tim(nj)
07-11-2001 10:37:18
 Re: Re: Loose knots off Ford 530 baler in reply to Ken Goth (MO), 07-11-2001 09:36:35
Could also be the twine holder disks need to be tightened a little.
