Kubota B6000-E / King Kutter Grooming Mower
Rob Barter
06-25-2001 09:13:01
I've bought a used 48 inch grooming mower, the first time I used it was the blades started to come off so we bought some New ones and bought new bolts and washers. When installing them we saw they were different they were bevelled opposite than the ones just removed the old ones were doctored up but when we checked the manual the new blades were the right ones called for but after putting the new blades on they are rotating in the wrong direction, we check the belt and it was on correctly, but is going in a clockwise direction and needs to be turning in conter clockwise can't fine the problem if anyone can tell me what the problem might be PLEASE HELP!!!
RMD
06-26-2001 06:50:53
 Re: Kubota B6000-E / King Kutter Grooming Mower in reply to Rob Barter, 06-25-2001 09:13:01
You don't say if it's driven from the rear or front PTO. The rear PTO on a B6000 turns opposite of most PTOs, so you need implements designed for the B6000. If it's driven off the front PTO (belt pulley), you just need to put a twist in the belt to reverse direction.
