John Deere 14 2-bottom plows
Thomas
06-21-2001 16:21:51
I need help identifying an old set of JD 14" 2-bottom plows. Number on crossmember is no. 4 followed by what appears to be the letter "L" but i'm not sure. I need to buy shares,shins,wearpads,and landsides so that i can do a little plowing. Would appreciate any input.
Ron
06-22-2001 07:48:57
 Re: John Deere 14 2-bottom plows in reply to Thomas, 06-21-2001 16:21:51
It's probably a model 44. And likely you are up the "proverbial creek" trying to find those parts. If you find some let me know as I will eventually need some too.
Tim(nj)
06-22-2001 13:29:45
 Re: Re: John Deere 14 2-bottom plows in reply to Ron, 06-22-2001 07:48:57
The best thing to do with those old plows is to find an F125, F145, 444H or 555H with high speed throw-away bottoms in a junkyard, and buy a couple of complete frog assemblies off it. The bolt pattern should be the same for mounting to the beam, if not it could be adapted. Then you can use shares, shins, moldboards and landsides that are readily available from aftermarket suppliers like Adams and Wiese. Some 44s were sold with the high speed bottoms in 1953, according to an old JD pocket ledger from that year that I have.
