John Deere 14t
Bryan Renkas
06-20-2001 07:39:51
Also with our jd 14t every time you shut the pto off it sheers a pin. Is the timing off or something any help fixing that. Also i still need a operators manual for it.
Fudd@Work
06-20-2001 20:55:07
 Re: John Deere 14t in reply to Bryan Renkas, 06-20-2001 07:39:51
The slip clutch has a set of dogs in it that act like an overrunning clutch. If this is stuck, it will probably do this.
Fudd again
06-20-2001 20:56:57
 Re: Re: John Deere 14t in reply to Fudd@Work, 06-20-2001 20:55:07
You should be able to turn the baler flywheel backwards and hear the dogs trip. Good luck.
craig
06-20-2001 17:27:24
HI, when shut down do you hear any loud bangs. Is the dogs staying down or is the pluger hitting on them, also check the needles they may be droping down a little my thoughts craig
Steven M
06-20-2001 16:40:21
You can get a operators manual from John Deere,go to your John Deere dealer,or call John Deere Publishing at 1-800-522-7448
