What is this thing?
David
06-19-2001 09:27:27
third party image
What is this attached to my ford 3600. It bolts under where the drawbar would go and has arms going up to a rocker thing and bolting to the pumpkin. I need to remove this to attach a drawbar plate.
Jiff
06-22-2001 15:18:10
 Re: What is this thing? in reply to David, 06-19-2001 09:27:27
Was your tractor imported from Europe, if so, this would explain the factory cab. The pin is for towing an implement, wagon with an oval or round hole in the drawbar, there should be another piece that would drop down over the top of the pin to keep the tongue from jumping off the pin. I have seen these on JD tractors in the UK, the pin would lower to the ground and get under the tongue, then the operator would raise it up and capture it under the keeper. I knew a dealer in Northeastern England that would export Ford Tractors to the US to be auctioned.
Duane(Pa)
06-21-2001 13:06:58
I've seen that on another 3000 But I have no idea what it really does.
JHEnt
06-19-2001 17:42:05
You have a 3600 with a factory cab? Thats rare. As far as the thing your asking about, I have no idea what that is.
David
06-20-2001 08:08:14
 Re: Re: What is this thing? in reply to JHEnt, 06-19-2001 17:42:05
third party image
Yep! and I wish I did not. That cab has been in the way since I got it. Here is a pic of the cab
