MF 36 hay rake gearbox questions
Jim.UT
06-18-2001 19:26:55
I'm the new owner of an old MF 36 rake. The gearbox has a round rod bent into an "L" coming out of the top. An aircraft cable is attached to the rod. I'm assuming the rod and cable setup is how you engage the bars. So far I haven't found the right combination. Do you rotate it forward? Pull it up? Should it be easy? This is not.
Also, I see a drain plug on the bottom of the gearbox, but I don't see where to refill it. I've been looking for a manual, but so far no luck. Any help is appreciated.
pappy
06-19-2001 01:34:04
 Re: MF 36 hay rake gearbox questions in reply to Jim.UT, 06-18-2001 19:26:55
I have a new idea rake, the cable on mine pulls the lever down into the gearbox, the cable runs under a pulley wheel under the lever,and you have to push the lever down and rotate the bars to get into gear after you tighten the cable.HTH pappy
Tim(nj)
06-18-2001 20:48:44
A friend of mine has one of these rakes. When you pull the lever, you may have to manually turn the rake bars a little until the clutch fully engages. I'll ask where he puts in gear oil.
Jim.UT
06-18-2001 21:04:17
 Re: Re: MF 36 hay rake gearbox questions in reply to Tim(nj), 06-18-2001 20:48:44
Thanks, Tim. I tried that. It doesn't seem to make any difference. The rake bars turn freely while I lean on the gearbox lever. I don't seem to feel any connection at all between the gearbox lever and the motion of the rake bars. Maybe something's become disconnected in there and I need to start removing the gearbox cover.
