Soil Prep for Planting
MO
06-17-2001 15:13:06
Which implement would be the best to use for leveling and final smoothing of the soil for planting? First, I used my two bottom plow (behind a 9N) to turn over the ground. Then, it was disked. It was still a little rough, so I went over it with a tiller. This broke the soil up real fine, but did little to level it. In fact, it probably made it rougher by leaving little furrows. Would a cultivator smooth it real nice, or is there something else better to use? Thanks for the help!
MO
Tom-nj
06-18-2001 17:09:47
 Re: Soil Prep for Planting in reply to MO, 06-17-2001 15:13:06
One way to level out is to tow a 8 ft. long pipe 4 inches in diameter behind the disk. If you really want to make the pipe heavy fill it with concrete.
sammy the RED
06-17-2001 19:00:11
Spring tooth harrow.
paul
06-17-2001 17:00:59
Around here (southern Minnesota) the best way to do it is plow in fall, then field cultivate (or disk) in spring, then run over it with a harrow (drag) if you want it really level.
In spring the ground is just so wet & lumpy & dries hard, never do get a 'good' seedbed unless you get lucky with timely rainfalls to mellow out the soil.
Conditions might be different where you live however.
--->Paul
