NEW HOLLAND 310 BALER
GRADY COWART
06-16-2001 16:39:48
I NEED INFORMATION ON THE TYPE SPRING AND WHERE IT IS ANCHORED FOR THE TWINE FINGERS.
robtha99
08-01-2004 09:01:04
 Re: NEW HOLLAND 310 BALER in reply to GRADY COWART, 06-16-2001 16:39:48
hi, i am looking for parts also, if you have any parts please email me. thank you, bob
RickB.
06-17-2001 05:26:09
It uses one coil-type extension spring. Hooks over the left hand side of the right hand knotter frame, hook to the left. You should see a spot on the frame where the paint is worn off. Other end hooks to a hole in the arm of the pivot rod. Some folks use a spring on each knotter, but one is correct. Most New Holland dealers will have that spring in stock.
