Ledger plates on Ford 515
C.C.
02-22-1999 21:56:24
I've got an older Ford 515 mowing machine and am about to change several of the guards. The ridges are worn pretty badly on the sides and I'm worry that it won't give a clean cut. I noticed in the manual that you can change what they call Ledger plates on each guard. Does anybody know anything about this? The manual does not go into great detail about it, in fact about all it says is that it can be done. Would it be more cost effective than changing the entire guard? How much harder would it be than changing the entire guard? I'm pretty new at this so any help would be great. Thanks. Casey
Paul Fox
02-23-1999 03:31:15
 Re: Ledger plates on Ford 515 in reply to C.C., 02-22-1999 21:56:24
I don't have any experience with your particular mower, but I'm going through the same process on an Allis mower, and I expect the procedure is about the same.
New guards with ledger plates are a bit over $8 each. New ledger plates and rivets are a bit over $2 each, so yes, it makes sense to replace the ledger plates if the rest of the guard is in good shape.
They are held in with a countersunk rivet on the plate side that is peened over on the bottom side of the guard. I hit the bottom of the guard very lightly with a angle grinder and drive the old rivet out with a drift punch. I've found that I have to touch up the alignment notch on the rear of some of the plates so that they fit over the boss on the guide correctly, but other than that, they drop right in, stick in a rivet and peen it over. This works best with the guard off the bar so you can set it on an anvil of some sort to set the rivet.
Hope this helps.
C.C.
02-23-1999 08:26:31
 Re: Re: Ledger plates on Ford 515 in reply to Paul Fox, 02-23-1999 03:31:15
That's all I needed to know. Thanks a million. Casey
Miles
02-23-1999 13:22:28
 Re: Re: Re: Ledger plates on Ford 515 in reply to C.C., 02-23-1999 08:26:31
In my local Bomgaars store {TSC} they sold the guards with new plates for $3. I don't know if they are any good.
paul
02-28-1999 19:10:00
 Re: Re: Re: Re: Ledger plates on Ford 515 in reply to Miles, 02-23-1999 13:22:28
Be careful of 'universal' gards & older Ford mowers. There may be a very slight difference & will not fit.
--->Paul
